WD running rough, no power and killing |
kofted
Topic: WD running rough, no power and killingPosted: 03 Jun 2024 at 6:01pm |
My WD started running rough, not having power and killing. I would appreciate any help. I need help on troubleshooting.
- Checked inside the tank: Clean - Checked fuel flow from tank to bowl, bowl through line, and then cracked the drain on the carb. All is good - removed the carb and took all apart, inspected and cleaned. Was not much to clean. - Adjusted idle mixture screw to 1 1/2 turns out. Set load screw to approximately 1 1/2 turns out. - Checked the plugs (running Campion J8C). All are black. Cleaned them all . Set them to .030" I turned it over with plugs out to check the spark and it looks good. - Checked the points over. Some cloudy/discoloration on them. Polished them up, set them at .020" - Took the valve cover off and cranked over. All valves seem to move as they should. I have had this tractor for about 30 years and had very little problems with it. I keep it in a shed. It has the magneto. I run it about 50 hours a year with a back blade and a brush mower. Edited by kofted - 04 Jun 2024 at 8:46am |
Les Kerf
Posted: 03 Jun 2024 at 6:37pm |
It's probably time to have the magneto rebuilt and recharged.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88649 |
Posted: 03 Jun 2024 at 9:02pm |
you can randomly try a new coil and condenser to see it that helps.. I have done that a couple times with success... 6 months ago i bought a "reconditioned" unit off this site from one the "rebuilders" and it made a world of difference.... Getting a new coil / "GOOD" condenser and point and recharging the magnets and new parts for the impulse is a LOT more than i was doing... and it runs GREAT.
Edited by steve(ill) - 03 Jun 2024 at 9:02pm |
