Kawasaki mule |
Post Reply ![]() |
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2970 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Jun 2024 at 7:49am |
Time for the first service and I'm thinking about doing it myself. Anyone have any experience with this? Thanks
Ron(AB) ![]() Orange Level ![]() ![]() Joined: 27 Dec 2009 Location: Alberta Points: 962 |
Drain oil, change filter and refill with new oil.
Was there something else you were thinking? |
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Thanks Ron, heard the dealership also checks valve clearance and makes other checks
Oil and filter change I can handle, Thanks again |
ac160 ![]() Silver Level ![]() Joined: 02 Dec 2010 Points: 408 |
It is pretty easy to do the service on the mule. Just drain the oil for front/rear diff as well as the engine oil is what the manual I think said. Hardest part was squeezing under it to drain the oil as I didn't put it up on anything.
Sounds good , Thanks . I'm hoping to get a service manual for Father's Day .
only AC orange ![]() Orange Level Access ![]() Joined: 06 Dec 2014 Location: Eastern Indiana Points: 524 |
Hope it's easier to service than it's little brother - Teryx!!!
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5102 |
Yea right, The dealer actually do a valve clearance or other checks? They might haul it back to the shop change the oil at an inflated price keep it a few more days and then return it. Then bill you for PU & Delivery oil/filter change at inflated price plus a bunch of other things that they didn't really do. The economy is terrible when everyone can afford more than what I ever paid for a new P/U for a glorified golf cart to haul their a$$ around.
Yeah Paul , how do I know what the dealer does or who does it ? First service is $300 . I ordered a oil change kit . Gonna change the engine oil and see how it goes . Have to admit the wife and I do take our granddaughter around the block some , but I bought this mule to help keep the roads clear down at the "farm" . It's 4 wheel drive and easy to haul a chainsaw , etc in . Thanks
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87768 |
most of the engine valve covers have an o-ring seal for the gasket these days.. Easy enough to pop off the 4 bolts to get a look at the "valves and cam" area.... If you want to prove to yourself that the valves are still "OK"... just rotate each piston to TDC and check the clearance with a feeler gauge.. Dont need to ADJUST... just check and verify.. No real tools needed other than socket to get the cover off.
Some UTV like the Polaris have a "limit slip" type axle and require a specific fluid in the axles... I think the Mule is pretty standard and just takes 80- 90 gear lube ??
Thanks Steve, good to know.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3904 |
blow out the clutches and check the rollers libe pins and rollers carefully with fine powdered grafite use very sparingly so it does fling it a ll over the sheaves and belt good working clutches is where all your perfomance and power and smooth operation is at
Thanks Mike
I'll check that out |
Post Reply ![]() |
