D17 series IV
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: D17 series IV
    Posted: 01 Jun 2024 at 10:39am
My neighbor’s pto engagement shaft broke off at the handle flush with the transmission housing. Looks to me it’s going to require a split to repair. Haven’t been out to look at it yet. Is my assumption correct?
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 3:57pm
Yessir, you are correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 10:26pm
Went by to look at it and it snapped of flush with transmission housing and flush with handle. Looks like a split in the winter. He has plenty of AC tractors to run his Tedder.
Edited by AC720Man - 01 Jun 2024 at 10:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 10:42pm
If you tear into over the winter and aren’t rushed for time… I would highly recommend dropping the hydraulic sump and cleaning the screen, clean the screen for power director oil pump too, and disassemble and inspect / repair power director clutch (or at very least, adjust it per service manual, which is very simple while it’s accessible) Make the split worthwhile, since it’s a fairly time consuming job, and you’ll have some money in gaskets, seals and oil. May as well get the most bang for your buck while it’s down for the pto lever repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 7:05am
Thanks, I appreciate the advice.
Stan R View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 5:05pm
We had our D17 IV welded in place 30 years ago. Though about 8 years ago the inner o-ring weeped oil so we split it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 5:53pm
I considered suggesting that, but figured the heat from welding would cook whatever is left of the shaft o-ring and it would just leak. Would get him back to work with it, though, in a pinch!
A-C_220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 6:03pm
I have removed the lever before without splitting by removing the side cover and pushing the pin out with a bolt welded to a strong prybar. It can be tough but usually beats splitting the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 6:19pm
this must be somewhat common if more that one of you has it ???   Did this change from the series III  ?  Never had a problem with ours.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 9:51pm
I wondered about welding it but am not familiar enough with this model to suggest it.
It would need to do a lot more than weep before I would split a tractor, maybe crying great big crocodile tears of oil leaving a significant puddle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 6:07am
Quick weld and quick cooldown. Our weep was a drop maybe every 5 minutes. Though the o-ring maybe just needed replacing due to thousands (??) of pto engagements.
Just make sure what orientation the lever was in before it broke?
Edited by Stan R - 03 Jun 2024 at 6:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 6:27am
Fully disengaged to the detent puts the lever at straight UP 12 o'clock high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 10:02pm
His dad said he was disconnecting the pto lever when it snapped. Can’t say if it’s totally disconnected or not until I have him start the tractor to see if the pto shaft is still turning. Will go by and have him start it to see. He ran a wheel rake with it yesterday, I should have looked then. I did ask him to check the fluids before continuing to use the tractor. I’ve never heard of this happening before. Obviously I would have never continued to use it in this condition but it’s not mine.
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 7:10am
I'd like to follow up on Steve's question of whether this is a fairly common breakage, or is it due to operator abuse of some kind?  It seems that if the clutch is disengaged, even if the pto is still moving, there is very little force needed to disengage using the lever.  Hard to imagine normal usage like that would cause a fracture in the rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 7:17am
Foot clutch down. High inertia implement still spinning. Power Director clutch in low or high range. Maybe tractor still rolling in gear. Yup. There is back pressure against the sliding coupling and makes the lever pull HARD and after 50 or 60 years the weld failed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 7:46am
The lever is still available from agco
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 10:01pm
Pto isn’t turning when tractor is running at this point so it is disconnected.
1963D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 2:15pm
Would it work to drill a hole in the lever and a hole in the shaft and then weld it? To me that would be better than flush welding
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 3:48pm
Thats what Id do
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 7:48pm
Drilling the hole in the lever was my thought but had not thought of a hole in the shaft? Waiting to see what Jake wants to do. What is the thought process of the hole in the shaft as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 8:22pm
Does this just give more welding material to hold?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 8:50pm
Since the weld starts internally in the shaft it gives more surface area to hold. Its almost like you are creating a bolt
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2024 at 9:00pm
I havent looked at mine but if theres enough shaft sticking out you could weld some small key stock lengthways the handle. Grind the end of the shaft so the keys would have a notch to fit in. Drill and tap the shaft drill a hohe in the handle and bolt it to it. The keys would keepnit from slipping
1984 80780
1957 D14
616 tractor
