CA Oil Bath Filter Element |
| Author | ||
dfwallis
Topic: CA Oil Bath Filter ElementPosted: 31 May 2024 at 12:18pm |
Can someone clarify where this oil bath element is installed? I can't recall ever seeing an element in the oil bath pot. There is a mesh in the upper housing, but doesn't seem to be removable. Haven't found any online pics/illustrations.
1952 CA13092
| Sponsored Links | ||
dkattau
Posted: 31 May 2024 at 2:56pm |
You have to unsolder the bottom disk in the air cleaner housing and restuff it with the new element.
dfwallis
Posted: 31 May 2024 at 6:15pm |
Thanks. I was actually thinking that the top cap should have some sort of mesh material in it but every one I look at online seems to be empty. I'll look more closely, but I think the existing mesh is still in pretty good shape so I'll leave it alone for now.
1952 CA13092
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88647 |
Posted: 31 May 2024 at 8:51pm |
you can soak it in diesel fuel or laundry soap and flush / blow out with air and see what comes out.. connect a garden hose to the top and blow backward and see what volumn comes out the inlet... that will give you a good idea of what air flow you can get.
dfwallis
Posted: 31 May 2024 at 9:16pm |
It's been fully degreased/cleaned/sand blasted and painted. Just trying to decide if I've got all of the parts for it. It looks nice and clean and in good shape. I thought maybe the breather cap should have some mesh in it too though.
1952 CA13092
1955CA
Joined: 10 Sep 2018 Location: Ontario, Canada Points: 602 |
Posted: 31 May 2024 at 9:31pm |
I just cleaned and put new oil in mine tonight. My cap has nothing in it either. Glad you posted this though, because I bought all new packing and couldn't figure out how to get it in there.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7539 |
Thanks(1)
Posted: 01 Jun 2024 at 9:26am |
Caps have nothing in them. Their only function is to prevent water from getting into the air cleaner assembly.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5905 |
Posted: 02 Jun 2024 at 5:27am |
I believe most 'Oil Fill Breather Caps' (Eg. Engine and Hydraulic ) on the other hand do have a metal filter mesh in them to prevent any contaminants from getting in to the Oil System. G |
dfwallis
Posted: 02 Jun 2024 at 10:57am |
Yes, I have a new one of those. I couldn't find the old one anywhere. I had to paint it the correct color though, it came in black :(
1952 CA13092
