gleaner head on D17 issue |
CTALLIS
Joined: 22 Nov 2010 Location: Northfield Points: 619 |
Topic: gleaner head on D17 issuePosted: 30 May 2024 at 2:52pm |
put a gleaner head on my D17 and now my push rods are about an inch to short.
Anyone out there have longer roads or know if I have another problem. thanks
DrAllis
Posted: 30 May 2024 at 3:21pm |
Gleaner models "E" or "E-3" has the same HEIGHT head as any legit D-17 and the same length pushrods. Sooo your D-17 must have had a WC/WD head on it by someone which is about an inch shorter. Head bolts are different too.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2574 |
Posted: 31 May 2024 at 5:29am |
Pushrods are the same on all the engines. The only difference in valve train from tall to short head was the rocker stands. You need the tall head stands which are shorter. Anything from a WD45 and newer will work. Like Dr said, you'll also need the tall head bolts as well as the shorter valve cover. AaronSEIA
