tractor chuggs when mowing
teeitupfour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeitupfour Quote  Post ReplyReply Direct Link To This Post Topic: tractor chuggs when mowing
    Posted: 23 May 2024 at 9:58pm
my allis chuggs when mowing after mowing 20 min then stops chugging if I disengage the blades and let sit idle but then chuggs after 20 min again ???
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 10:12pm
sounds like somthing is in the tank blocking it
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 10:16pm
What size is your tractor? My 200 just went through the same thing. There was some debris caught in between the two fittings underneath the fuel tank on the right side. Good luck hope this helps.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 7:42pm
Well we know it's an Allis! And it chugs. Lol. Everything else is a mystery. May the best guess win!!!!  Smile  Smile
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 8:07pm
Have a 200 here. Went through similar problems. It would also run hot. Granted, it was hot outside but losing power wasn't right. I changed both fuel filters which didn't help much so I disconnected the fuel line at the inlet side of the first filter. Very little flow from the fuel tank. Blew compressed air in the line back to the tank and have had no issues since. Granted this is likely to happen again but am not going to do a proper flush at this time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 8:48pm
There are a lot of guys here that will help you but you need to give a lot more info on the tractor and problem.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 9:25pm
It appears they don't give a chit. Scammer maybe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 9:06am
I don't understand the nomenclature. What does it mean to "chug".  Does that mean it runs or stops running?
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 9:31am
Probably a bad rendition and relay of the problems/symptoms. Lot of variable(s) but would need to know gas, diesel, fuel gas, etc.
New poster so very well could be spam of some sort.
That's All Folks!
