Does anybody know |
Post Reply |
Model 70
Bronze Level Joined: 09 Jan 2021 Location: Minnesota Points: 123 |
Posted: 22 May 2024 at 7:37am |
Anything other than the check valve between the manifold and valve stack that causes the 3 point arms to settle on a D19. Thank you.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7303 |
Leaking seals on the lift cylinders. As my local John Deere dealer used to say about lift arms drifting down: As long as you do not sleep under the cultivator, you will be fine.
Model 70
I will check out the cylinders,good point to not sleep under a cultivator 👍
Post Reply | |
