Plug for 7045
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Plug for 7045
    Posted: 21 May 2024 at 1:37pm
Some dummy (me) lost the plug for the hydraulic fill tube for the rear end, by the top link mount. Anyone have one they can part with?
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2024 at 4:16pm
I need one for a 7030 also! In a pinch a Donald Duck orange juice metal can will fit snug. Thats what mine came pimped out with.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2024 at 5:21pm
I dont know for sure but im thinking those plugs that expand when you twist a handle come in different sizes. Not like factory but get you by in a pinch. Maybe yes maybe no
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2024 at 5:32pm
what size do you want ?  .. You can get with a NUT on top or a TEE handle / etc..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2024 at 5:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2024 at 6:22pm
Yeah I can get something like that NP. I was just casting a line to see if by chance someone had “the right one “. Not a big deal, it’s not a showpiece.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2024 at 8:57pm
I'm pretty sure that it needs to be a vented fill plug in that location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2024 at 10:15pm
Factory plug is vented. That's why I tell every one to zip tie it to a piece of hardware store chain and a nearby remote cable. Didn't get much help from salvage yards. AGCO had it $$$$$ Mines out there in that 8 acre field somewhere.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 12:50am
Wondering what is the OD of the pipe? How close is it to the size of engine oil fill breather caps for like C, CA, D12, D14, D15, D17 engines.
 Or the twist n swell caps shown by earlier posts could be used if a vent (AC#229944) like in the AC200 trans top cover could be added or even maybe a couple small holes (under 1/8") were drilled in pipe just under where the rubber plug swells in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 4:21am
Vented? Well dang it that complicates things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 7:08am
Get a 7000 series transmission oil dipstick from a salvage yard and cut most of the stick off. Also, the 7030 and 7050s used a rubber fill plug like the engine oil fill plug. It was not vented and they switched to a smaller vented type.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 7:46am
What’s the part number
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 8:22am
AGCO part no.  7026270    79.50 price on line parts book
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 8:26am
sorry part no is 70269269
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 9:01am
i would use something like this... put a bigger washer on top so it does not slide down in the tube.. and put a short 90 degree rubber hose on top of the "vent" to keep dirt out..... again,verify tube ID.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 9:37am
Ford used an expansion plug on a lot of their tractors.  I know the 6610 and 7610 I have use them for the engine and the rear end fills.  They are not vented, though... but they are readily available
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 10:02am
well.......... this would be simple..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 11:36am
I would not have thought mine was vented. Why bother with snug o ring fit and flange cover only to vent it. Just a ring on top. I admit I never took that close of a look, and I don’t doubt you guys. Just wouldn’t have thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 12:57pm
for those that have a vent... where is the HOLE ?  slit down the side ?  Hollow shaft ?
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 1:42pm
On my 7000 there are 2 street 90's with screens in them, facing forward. So when I pull the dip stick out I see 2 orings to make it seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 2:20pm
A 7000 has two vents in the top rear cover,one for each final drive. It also has a breather for the transmission in the top of the shift cover. And, the dipstick for the rear end oil also acts as a breather for that compartment. The 7030 and 7050 tractors had some oil transfer problems between rear end and transmission compartment and there were also some rear axle leakage problems that the company thought was perhaps caused by the non vented rear ends. The rear axle leakage was usually caused by an undersized wear ring. They made an oversized wear ring, that fit tighter on the axle to cure them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2024 at 2:38pm
Snug fit so you don't lose it. My new one doesn't fit as snug as original.
