Allis G Oil filter base removal
BillyT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyT Quote  Post ReplyReply Direct Link To This Post Topic: Allis G Oil filter base removal
    Posted: 18 May 2024 at 11:17pm
the freeze plug behind the oil filter base is weeping and I want to replace it. I can't seem to loosen the filter base and remove it. Not much info out there about it but from what i gather its just pressed in the block. Started with a penetrant and a hammer and wood block with no luck. Been giving it some solid hits without the wood too but afraid im going to crack the base but its not budging. Been working on it for a while and trying to let penetrant soak in for a few days with no movement. Any help is appreciated. Thoughts on applying heat? Thanks
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2024 at 7:03am
I’ve always gotten them loose with a strap wrench, yes they are just pressed in
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
This page was generated in 0.035 seconds.
