wc tire setup
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: wc tire setup
    Posted: 16 May 2024 at 10:28am
i just picked up a 37 wc for my 10 year old son who is excited to have his own tractor and go pulling.  it has 12.4 x 28 rears which we will stay with for now as its a stock motor. my question is on the fronts.  it currently has the correct 6 bolt hubs.  I have some 5 bolts from parts tractors laying around which im assuming will fit?  would like to run some smaller tires on the front.  Looking for advice on what vehicles i can get donut spares to fit up there, (the 5 bolt) or suggestion on minimal work to accomplish.  I could buy some 3x15  b/c wheel blanks and weld in 5 bolt centers cut from old wc/wd rims but time you buy new tires, tubes and rims your looking at half the price of the tractor lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2024 at 3:00pm
If it was me, I'd make a set of 6 bolt centers to weld into a pair of 12" rims for 4.00X12 front tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2024 at 3:51pm
  Browsing the net after seeing your suggestion, i see that is a common size for trailer tires and a complete tire and rim can be had for about $75.  All that would be needed is fabbing the 6 hole disc to weld in.  I will look into this a little more.  Thanks
Unstyled View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstyled Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2024 at 7:50pm
Hey Wheel lists 4x12 rim blanks for $49
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2024 at 8:01am
found a pair of 4.80x12 new on ebay for $112!  says washington USA, likely jumping point from china lol
