Rear seal and oil pan gasket
Kenter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenter Quote  Post ReplyReply Direct Link To This Post Topic: Rear seal and oil pan gasket
    Posted: 15 May 2024 at 10:56am
First Question, can you change the oil pan gasket on a WD without removing engine and are to able to change the rear crankshaft gasket after removing oil pan?  And what is the best gasket to get? Thank you
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2024 at 5:40am
I think you can do the pan gasket, but the flywheel has to come off to do the rear main.  I've had good luck with the gaskets from DJS.  Don't forget to buy the clips to hold the end gaskets in.  Watch this video and do exactly as he says.  Oil pan seal and gasket install - YouTube
AaronSEIA
