unstyled wc radiator repair
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: unstyled wc radiator repair
    Posted: 31 Oct 2010 at 5:59am
I have a leak between the radiator tank and where the top radiator hose hooks up. It looks like the manifold part is rivited to the tank and has a gaskit inbetween. does anyone have a good fix for this?
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 7:38am
It is rivited and soldered.  Take it to a professional .The cast inlet takes a lot to heat to get to soldering temps, if your not skilled you will loosen a lot surrounding joints such as the tank to the header, creating more work.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 8:16am
I don't even mess with them anymore, the local radiator guy cleans, tests and fixes most of them for $25- $35. Don't know if all shops are that reasonable or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 8:24am
I will take it to a good radiator shop and get it fixed right. Last weekend I hooked up a plastic gas tank and cleaned up a fm 4 mag I had and it started on the second pull of the crank. I never had to clean the carb because it had been drained and it sat 30+ years.
This page was generated in 0.043 seconds.
