Fergusin TO-35 stuck in 1st gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: Fergusin TO-35 stuck in 1st gear
    Posted: 08 May 2024 at 7:59am
OK, neighbour's tractor (she's 6th gen on her farm..)....
 Gal was bushogging with it and 'somehow' got it jammed into 1st.
At least she was smart enough to park where reverses isn't needed, whew...
The high-start-low  shifter works fine.
I tied whack with wrench, didn't budge..
64K$ question... ANY 'magic' to fixing this or do I( lucky me...) have to tear 1/2 the tractor apart to remove the top of tranny case to 'free up' whatever's  jammed ???
As always, all 'words of wisdom' appreciated !
Jay
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 11:49am
Take oil fill cap out and use a long screwdriver to move shift rail thats out of place. A light helps you to see shift lever and rails. Common on them when shifter get worn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 7:10am
thanks !!!! I'll try that before I get stuck driving it home to work on..
but Mr. Murphy 'suggests'  it'll be in my garage ..sniff ,sniff..
