mystery tube
lost in h3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Topic: mystery tube
    Posted: 06 May 2024 at 9:41pm
On my H3 which is just about complete there is a tube at the back left side of engine. This tube does not have a cap (lost). To be clear, when sitting in seat it is in front of gas tank on left and behind engine. i do not know what this is for. Does a dip stick go in it or a breather cap. I can't even figure out where it goes. I'm close to changing all fluid's and need to figure this out.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 10:04pm
This tube about an inch or so tall at a bit of an angle outward with miniature radiator neck on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 10:40pm
Exactly
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 6:38am
It should be a dip stick and breather cap. Same as on a d14 or 15
Post Options Post Options   Thanks (0) Thanks(0)   Quote lost in h3 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 12:54pm
thank you
what is the dip/breather for and do you add fluid there.  how long is the dip stick?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 3:24pm
If its on the torque tube, about 4-5" long, and its for hyd pump reservoir, if so equipped...at least on a d-14-15, nit its on the other side...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 6:49pm
Depends on how the crawler was set up. It is the circulation pump for shuttle and in some cases it’s the hyd pump too.
This page was generated in 0.270 seconds.
