PTO and Clutch operation on a WD45
waltermrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waltermrich Quote  Post ReplyReply Direct Link To This Post Topic: PTO and Clutch operation on a WD45
    Posted: 01 May 2024 at 12:40pm
My WD45 clutch stopped working the other day the tractor will not move in any gear with the clutch engaged had it 24 years and no sign of clutch problems , I noticed the PTO would grind while trying to engage it even with the tractor stopped and no movement of the tractor , is there a relation ship between the PTO and the clutch that may have broken.?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 9:00am
The pto works with the foot clutch, drive tires with the hand clutch. If things are right, you should be able to kick the hand clutch out and pto still run but forward movement stop. If it doesn't move forward but the pto works, your problem is in the hand clutch. Not unusual for the pto to 'grind' going into gear. Be gentle and patient and it will slide into gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 10:13am
Lock the brakes tight. Start engine. Shift into 4th gear. Hand clutch FORWARD (released). Shift PTO fully into gear. Let out the foot clutch. Is the PTO running or NOT ??? If the PTO turns, now pull the hand clutch all the way back. Does the PTO STOP ??? or stay running??? If the PTO stops, your foot clutch is bad. If the PTO stays running the hand clutch is bad. Might take two people to do this or tie something on the PTO so you can see if it is turning or not from the seat.
This page was generated in 0.035 seconds.
