cylinder hone grit
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: cylinder hone grit
    Posted: 30 Apr 2024 at 9:40pm
I finally got dads old D-17 gas freed up.  The head is off and want to clean up the cylinder that was stuck.  What grit of stone are people using to clean these up?  I know it will probably use a little oil but dad is 84 and getting out of the hospital and will not get worked very hard at all just plan on using it on a rake.  Kind of a surprise for him as its been sitting for the past 5 yrs
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 9:42pm
I was thinking 180?  Rabbit t**d hone?  Any thoughts
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 9:48pm
YEP... thats what i would do in your case... Could be 240... but the 180 might clean up more of the "damage"..
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 9:55pm
thank you ive used the rabbit t**d hones before and the work rather well just couldnt remember what the final cross hash marks should be
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 10:27pm
clean al then rust and crud out first or you will fill the hone up and it will hone the  clean spots and not the dirty spots
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 1:31am
Do you know anyone near you with a sandblast cabinet ? use it first and only to remove heavy scale, it will save time and the hone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 7:50am
If it's just 1 cylinder, you might just replace that 1 sleeve with a good used 1.
I personally would use a flat stone hone because it will only hone the high spots, not make the low spots lower.
