8050 right hand fuel tank
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: 8050 right hand fuel tank
    Posted: 30 Apr 2024 at 8:38pm
The right hand tank took to leaking. Is there any repair to those plastic tanks?
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 8:42am
There is, we repaired a leak on an 8070, got the kit from agco, but NAPA or O'Reily might have one as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 10:22pm
I got some stuff from JB Weld. I put it on and let it sit overnight. I put fuel in it this morning and so far it appears to be holding.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 6:43pm
I repaired a gas tank on an '02 1500 pickup with a borrowed soldering iron with a wide, flat blade. I emptied the tank first of course, used the hot iron to heat the plastic and a deadblow hammer to move it back into place.  Then used the hot blade to smooth it over.  It's held for over 2 years now.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 6:01am
Good luck to you with that. I hope it holds for you for a long time
Darrel
nanuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nanuk Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2024 at 4:49pm
I have a 2003 Ram with plastic tank. Huffer put a hole in it with an awl, took a bit in a cup, left the rest to drain on the ground.
I found a big metal screw and washer that fit snug.
Cleaned and roughed the area real well.
Gooped them with JBWeld and screwed them in snug, then mucked completely over the whole area.
Hasn’t shown a damp spot yet 2 years going.
AC7060Pd 1975
