Allis Chalmers 190 relief valve housing stuck
Allis Eli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Eli Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 190 relief valve housing stuck
    Posted: 29 Apr 2024 at 4:08pm
hey everyone having issues on my 190 gas. the tractor has a bad 3 point relief valve. I ordered a new relic valve but when I tried to pull the back one out only the center part came out. the housing was still stuck on the valve stack. I tried using a wrench did not work. same with a vice grips. how would you guys recommend getting the housing to come out?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 5:05pm
Strike hard on it with 3 lb hammer to loosen the threads. Hit the end of the cartridge squarely more than once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Eli Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 5:14pm
okay sounds good Thanks DrAllis
