Field drainage tile
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Topic: Field drainage tile
    Posted: 29 Apr 2024 at 10:48am
I own a deep 40. 1/8 mi wide by 1/2 mi deep. The very back 10 acres (of woods) has a county drain ditch that runs thru. Getting ready for the field tile crew we cut a path thru the woods to the ditch to run the main. I remember the 'panic' of 'wrecking' such a big area of my trees, the saw was in my buddies hands and he went to town clearing a path.
25 years later, well probably started 5 years ago, the end of the field was too wet to do anything with. Every year the spot got larger until this year when the woods is flooded and the field is swamped. The tile is plugged and only dropping a 1" diameter stream off the end of the pipe.
The neighbor is an excavator. I got him back there last year and he exhumed a 8 foot long plug out of the tile. Tree roots. The obvious culprit was 20, maybe 25, feet away. This year was more of the same, different spot only 100 feet or so before the ditch with the offending tree probably almost 35' away. The tile went from dumping an inch of water to like 4 or 5 inches of water... But...
I've had it. I'm going out this spring and cut down every tree within 50 feet of the tile. Screw the deer and the squirrels we are going big. Probably have the excavator back to push up all the stumps so I can do something with the open area.
Years ago I wish I had advise from a FOG saying cut (more of) those trees down. Those roots will travel a long ways and infiltrate a solid, no perforations, drainage pipe. Feeling bad for the trees we cut was stupid, I still had tons of trees left after we cut the initial path and then the sun got thru and suddenly we had grass growing in the woods, yes with deer and squirrels. Even the tile guy never got 'excited' by my less than ideal situation. Years later it seems the correct answer has become to clear a 100 foot wide swath and get the roots waaay back. I wish I had understood that back then...
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 2:31pm
Or go along the tree line with a root cutter every so many years
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 7:00pm
Depending on what kind of trees, 100 feet might not be enough. If it’s cottonwoods, you might think about going further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 7:41am
Tree roots should not be able to grow through solid pvc that is properly glued and installed. Now when a crack or opening is available roots can grow through a hairline crack . Problem today is high quality schedule 40 pvc is expensive. About 50 dollars for a 10 foot length. They do come in 20 foot lengths with bell ends but have not priced any lately. There are cheaper pipes but you get what you pay for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 9:34am
The 'solid' pipe thru the woods is a flexible black 6" corrugated pipe that was laid in place by the Tile Machine. If there were stones or whatnot I could see where it might have been damaged slightly knifing it into place.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 10:38am
tree roots have no problem going thru that flimsy black plastic tile!! It comes either slotted OR solid and trees will go thru either one in a heartbeat.
IF you use solid then you have to step up to sewer grade white thick wall stuff and sit down when you see the price of that stuff!
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2024 at 8:27pm
Why not just have an ‘open ditch’ or a concrete lined open ditch in the woods? Or better yet a ‘waterway’ leading to the county ditch?
Edited by Lars(wi) - 30 Apr 2024 at 8:30pm
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 2:42am
It might be cheaper to run a new main but this time run a few bare cooper wires along side the tile. The copper wire will keep the trees from plugging your pipe
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 11:22am
Lars, that would work. It would be a deep ditch and cut the woods in half.
Bob, the idea of a new main thru the woods has crossed my mind. The tube is knifed in with a tracked tile installation machine, there would be no way to get the copper wire in.
LicBarrett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LicBarrett Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 7:27am
I've had similar drainage issues and found that hiring a Gutters contractor who also understood tile layout really helped. They were able to suggest slight grade changes and properly route surface runoff so it didn’t overload the tile system. Sometimes the problem isn't just underground—water buildup from roofs and yards feeding into one low spot can throw off the whole setup.
Edited by LicBarrett - 10 Jun 2025 at 4:16am
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 8:39am
I fell for you. I like my trees. Just put in a little tile here. 40' form the edge of the field where those little short annoying willows grow.  Tile said get those cleared out fast or there will plug the tile in a hirry looking for water. even 40' away.
I used to hear that the trees roots go about as far as it's crown.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 2:08pm
The update is we got the trees cleared back 75' from the tile main last year and the end of the field dried up this year, it must be working!
AC7060IL View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 10:43am
LarsWI, has the right idea (surface ditch thru the timber). No concrete. Why? Because gravity always works for an UNOBSTRUCTED downhill grade FOR WATER.
Tree roots inside the timber are your friends. The smaller shrubs, saplings, & grasses can compliment trees ONLY during off seasons & pre-seasons. As the optimal Tree season takes over, most smaller plants will struggle to compete in a solid wooded timber setting. Thicker tree leaf canopy quickly reduces photosynthesis. And tree roots dominate soil nutrients/moisture.
So if a ditch is excavated, annual MAINTENANCE (bush hog) is crucial to keep small trees from re-capturing that vacant ditch area. The optimal bush hog season will probably revolve around area’s droughtiest month(August?). Mowing then will hit smaller plants hardest with a dramatic set back or fatalities? Or in the case of perennial grasses, mowing can improve scattering it’s seeds for its upcoming fall germ/growth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 4:10pm
Willow and Swamp Oak will run a foot of New Root to a source of water Per Day.
