190 gas carb
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 190 gas carb
    Posted: 25 Apr 2024 at 9:03am
will a carburter from a 190 be to big for my d17 engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 9:21am
Many years ago I ran a 190 XT (bigger than 190) carb and even had a larger venturi in it. Manifold had to have a larger neck welded to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 11:00am
190 lp
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 5:44pm
found picture that i was going to rob carb off of   and it is a lpg 190 xt with a lp carb  thought that it had been replaced with a holley ,  next option is a loaner carb off a gleaner c hillside with a 262
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2024 at 10:06am
We tried D19 and G Gleaner carbs - unless the throat is opened up to the diameter of the butterfly or venturi - it will not help. We had the intake throat drilled to as large as we thought safe, we had a plate made with counter sunk screws to attach to manifold and wider holes for the carb with the ears of the manifold ground back on ends. On the dyno - with WD pistons over bore, lunati cam, 2000 RPM - D19 carb - premuim gas right at 75 hp.  65 with a 175 carb. (about the same as factory)  Don't think the G carb off the 301 helped much if any. HP is one thing -torque is another. The larger carbs at much higher RPM's - which we didn't do back in the day - would have helped I am sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2024 at 10:49am
Heres where ole Mack could have great advise- he had a great running 190 XT gasser on the pulling curcuit-- but that is gone
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2024 at 3:40pm
we are doing some small block chevy valves and open ing everything upin the maniflold and head 1800 to 2000 rpm  175 cam
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2024 at 5:22pm
But, to efficiently make use of a true 190XT carb, you must cut off the manifold mounting throat and weld on a LARGER one to match the carbs larger throat. No adapters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2024 at 5:52pm
thats doable and easyer (welding on a new flange) than finding  a tsx 848 or a zenith 14997  unless i buy new . i think the d19 one will be the best for me,     how much differance on the inside will the 262 combine carb one be from the tractor one ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 6:03am
D-19 style carb can be made to fit the manifold with 1/4" bolts and nuts and machine out the manifold hole to match the carb. Early C-C2 combines used this size of carb. Later G-262 combines used the larger style 190XT Bendix carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2024 at 11:21pm
i got a little measuring in to day  and the manifold could be milled to slot the holes and just make it,   with out making slots all the way out to the edge  that would help keep it from looking modified and help keep the carb centerd good.    i have been looking at a brand new zenith 14997 on the internet suposed to be the tsx 848 replacement .  i do have the zenith of a d17 parts tractor it is the stock one  it will get me started .    what one is better between the zenith 14997 or the marvel tsx 848 ?
