7000 valves |
Post Reply ![]() |
Glen S.C. ![]() Bronze Level ![]() Joined: 18 Sep 2009 Location: Irmo S.C. Points: 35 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Apr 2024 at 9:33pm |
Does the 301s have a problem with the valves breaking the lips on the edge off? When I bought this tractor 2 cylinders had broken valves. Rebuilt the engine , new sleeves pistons , had the head done , new valves in those holes. Around 150 hrs had a valve go bad. Shop put the intake and exhaust in the wrong holes, had that fixed. Saturday night started skipping . Pulled head today #5 intake half of the lip gone #4 intake cracked . Not sure the hrs since last repair. Going to have all new valves put in this time. Tiered of doing this. THanks for any input.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21932 |
No problems.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5026 |
Are your injectors bad? Bad injectors can cause combustion chamber problems.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Our 7000 lost one once. I don’t remember it doing the damage loosing one on the 8050 did. At one point it was worked fairly hard so somewhat understandable.
Edited by victoryallis - 25 Apr 2024 at 9:03am |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5097 |
as mentioned above, injectors faulty or installed wrong if Ambac or Bosch injectors, or inj pump timing can be off a long way. It's usually a poor state of tune that causes failures like this.
Thanks for the info . Will check all of that. Doesn't smoke. Did have some turbo trouble a while back but put a new one on .
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2390 |
That's pretty bad
Post Reply ![]() |
