Deck for T818 |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2593 |
Topic: Deck for T818Posted: 24 Apr 2024 at 10:58am |
Will a brand new simplicity 48 inch deck fit on my Allis T816?
Blue Skies and Tail Winds
Dana |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1082 |
Posted: 24 Apr 2024 at 6:10pm |
That depends on what the new deck is supposed to fit. What do you have for info on the new simplicity deck?
Mikez
Posted: 24 Apr 2024 at 6:48pm |
Should be a tag on deck with id number. That would help
captaindana
Posted: 25 Apr 2024 at 6:23am |
Ok ill check
Dana |
captaindana
Posted: 25 Apr 2024 at 5:24pm |
Hey MikeZ the new deck is from a Simplicity Regent
O/SIMPLICITY/2691456 is on the tractor, the deck has no tag he says but tractor model is 2691456. Does this make any senseš Edited by captaindana - 25 Apr 2024 at 5:28pm |
Dana |
im4racin
Posted: 25 Apr 2024 at 6:19pm |
Is it a stamped or fabricated deck. My gut says itās not going to work based on how the linkage connects on the front
captaindana
Posted: 26 Apr 2024 at 4:24am |
48ā FAB
Dana |
captaindana
Posted: 26 Apr 2024 at 4:27am |
Ya see my T816 came with a 48ā:deck and the fellow said he never had the deck running because of some āpartā he didnāt have. I have my owner op manual coming. So if this new available deck wont work Iāll try to get what I have going again. Thing is this new deck is unused. Thanks Dana
Edited by captaindana - 26 Apr 2024 at 4:28am |
Dana |
im4racin
Posted: 26 Apr 2024 at 6:31am |
With enough time and torch gas everything is a bolt on. Itās probably going to be a lot of reinventing the wheel. What part are you missing from the original deck?
im4racin
Posted: 26 Apr 2024 at 6:34am |
You should be able to download all the manuals from simplicitymfg.com. You will need the mfg number off the tractor. If you donāt have that number you can search on partstree.com by model number and it will show mfg numbers for that model.
Mikez
Posted: 26 Apr 2024 at 7:05am |
Your 818 decks main attachment is from front. Looks like that other deck is to the rear. Send me some pictures of 818 deck and Iāll see if I can tell whatās missing.
captaindana
Posted: 26 Apr 2024 at 1:18pm |
Dana |
im4racin
Posted: 26 Apr 2024 at 6:22pm |
I really donāt see anything missing
captaindana
Posted: 26 Apr 2024 at 7:56pm |
When i get time ill have to mount it maybe the tractor is missing something.
Dana |
im4racin
Posted: 26 Apr 2024 at 10:31pm |
The engagement rod probably is what is missing. It would run from the lever on I believe the left floorboard forward to the pivot on the left side of front mount on deck. It would pull the pivot rearward to engage the deck by tightening the belt and releasing the brake rod across the front of the center arbor pulley on the deck. Clear as mud?
captaindana
Posted: 27 Apr 2024 at 4:39am |
Yes sir I understand that. Ill need that! MikeZ!!
Dana |
Mikez
Posted: 27 Apr 2024 at 6:12am |
Iāll take a look in parts book for part number and see if have that rod
Mikez
Posted: 27 Apr 2024 at 6:49am |
#46 I believe is the rod. Iāll check see about having it ![]() |
