Pistons
Ol case mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Topic: Pistons
    Posted: 23 Apr 2024 at 1:21pm
Is there enough room to install wd 4-1/8 power crater pistons onto a gleaner z these are not wd45 power crater pistons I know sp46 need to be machined some to clear I was just wondering about the power craters
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2024 at 2:06pm
M & W piston kit SP-46 fits the 4 inch stroke WC/WD engines and have a Power Crater type bowl in them. If you install them in a WD45 or D-17 engine with the 4 1/2" stroke you need to machine .170" off the top so they don't smack the cylinder head. As far as what you're wanting to use, I have no idea what the compression distance/height is. Might work. Might not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ol case mike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2024 at 3:41pm
I have both sets MW 4-1/8
And the smooth bowl I thought them was called power crater that is also 4-1/8 set I was thinking about putting the smooth bowl into a gleaner z code I don’t know either pin height both are still in motors with wd cranks I was just wondering if the smooth bore needed any machine work to be installed like the sp46 piston needs it’s for a unstyled wc pulling tractor that has a stock z gleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2024 at 12:15pm
In the "KNOWLEDGE" section of this website, down near the bottom of page 1, you will find "Compression ratio calculator for 226 engines".....good info for you.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2024 at 10:24pm
got ross duplicating some sp46 pistons  (should be done any day now )for me as we speak thanks to steve fischer getting me a piston they are going in my d17 series 4 engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2024 at 10:26pm
they will be a two ring piston and lighten alittle bit
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 6:33am
And .170" shorter ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 8:39am
no i decided to leave them the same pin to top hieght, and mill them at the machine shop
This page was generated in 0.104 seconds.
