AC One Sixty hydraulics guit
thebigenchilada View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thebigenchilada Quote  Post ReplyReply Direct Link To This Post Topic: AC One Sixty hydraulics guit
    Posted: 18 Apr 2024 at 7:59am
Was using my tractor yesterday and is was fine, went out this morning fired it up and no hydraulics … cleaned the sediment screen and the main hydraulic filter and still have no action. Pulled the outlet line off the pump and no flow.
As I understand the hydraulics dumping out is a common problem BUT what needs to be done to get pressure back to the pump?… assuming it’s not a pump failure.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2024 at 9:40pm
Sounds you may be air locked. First check your transmission/hydraulic fluid level. If you have a 160, there is a filter near the seat. A square cap with 4 nuts holding it in place. Remove the 4 nuts and cap. Gently remove the plastic filter. After you examine it gently clean it in a parts washer or gasoline in plastic container. They are NLA so be gentle. So many of those don’t get cleaned and become contaminated. It will stop the hydraulics from working. The pump sucks oil from the sump through that filter. There is another canister filter to the right of the radiator. If it hasn’t been replaced change it and the oil if it’s due to be changed. 25 quarts if I remember correctly. Another thing to check in is the coupling hose on the sump line. At the bell housing where the 2 pipes meet check the rubber coupling for cracks and make sure the clamps are tight. After these areas are checked I plug a 4 foot hydraulic hose into the top rear remote, the other end into a clean empty hydraulic bucket to catch the oil as t comes out of the hose. Start the tractor and go to at least 1500 rpm. Have a second person operate the hydraulic remote back and forth until all air is gone and a steady stream of oil comes out. Move the hose to the next outlet and repeat the process. Once that is done operate the lift arms, they should be functional now. This process has always worked for me.
Edited by AC720Man - 18 Apr 2024 at 9:42pm
