220 hydraulic issue
cdreb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Topic: 220 hydraulic issue
    Posted: 16 Apr 2024 at 9:24pm
I went use my 220 yesterday after th mild winter. It started up left it sit while I opened the doors on the shed. Put it in gear but no hydraulics,no steering or lift arms. Any thoughts never done this ever. It’s is full of oil. Thanks in advance..
B,C,5020,D17,(2)-190XT's,220,D21,7060, Agco LT70
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2024 at 9:47pm
Lost it's prime. Isn't there a fitting on the top side? Would have to go look. Think mine has a cap nut somewhere  can remove and squirt oil in. Don't remember if it will prime by just leaving hyd line loose. Tighten your clamps on draw hose under pump. That's what fixed mine after same trouble. Extended setting makes it show up. Probably not appear with daily use. Pump is higher than sump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2024 at 11:09pm
Follow up? What did you find?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2024 at 5:31am
Sorry not feeling well I haven t circled back yet, Iwill check tomorrow.
