8070 flow divider pwr steering
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: 8070 flow divider pwr steering
    Posted: 16 Apr 2024 at 6:28pm
Think I need to pull sleeve out of flow divider because of sluggish steering. It wasn't this way til I ran low on hyd fluid when remote cyl hose sprung leak and I was unaware. How much oil is going to run out without draining it? I'm guessing only what's in the gear pump but don't know. Advice welcomed.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2024 at 9:54pm
You won't lose much oil  by taking it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2024 at 10:12pm
Thanks Lynn. Almost called you this eve but decided not to bug you and posted here so in a way I got my answer from you after all. LOL! Picture don't hurt either. Figured I don't have much to lose by trying.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2024 at 7:38am
Dropping the auxiliary fuel tank was the messy part for me. BTDT.   I was told to clean the barrel up good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2024 at 7:41am
I was hoping the fuel tank wouldn't interfere....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2024 at 8:04am
Fuel tank shouldn't bother if taken out from below.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2024 at 11:04am
It’s close
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2024 at 2:21pm
Looks like plenty of room. Haven't started on it yet....
