7040 trans light
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Topic: 7040 trans light
    Posted: 14 Apr 2024 at 2:11pm
I have a transmission pressure dummy light that flickers as I Drive my 7040. It doesn’t seem to be affecting the work -ability of the tractor, but I am concerned. I just changed the fluid and cleaned the screen and change the spin on filter and the light is still on. Anybody have any ideas? Thanks for the help earlier on finding the screen.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 4:21pm
Check the wire for rubbing and grounding out at times.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 4:46pm
Is the light coming on/flickering at or above 1800 RPM?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 4:54pm
Yes
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 5:54pm
Could be the sender. I had one fail instantly on engine oil pressure. Light came on running wide open. Shut it down. Got a guage and tested it. Had 75 psi. Boy that was a good feeling
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2024 at 9:56pm
Mine did the same thing. It wasn't connected and touching the frame. Go look at it.
80 7010, 80 7020. 67 190XTD Series I w/500 Loader, AC 2000 Plow, AC 4 row Planter, AC 77G Rake, Member Indiana A-C Partners, Member TAC
