Allis 5050 jumpy to no hydraulics
Allismass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allismass Quote  Post ReplyReply Direct Link To This Post Topic: Allis 5050 jumpy to no hydraulics
    Posted: 13 Apr 2024 at 4:13am
I purchased a low hour 5050 a few years back and the hydraulics are giving problems.
When hooked to an implement the tractor won’t lift (say a Tedder) smoothly.. it jerks and may not all all. Is it a bad hydraulic pump? I changed hydraulic oil, cleaned the filter, and even filled the pump from the top side to eliminate a possible airbound/cavitation like situation.. still does it.
I  also checked under the seat to see if the valve(?) was free. I found this on line on a Universal tractor.
I also lost the power steering after I noticed the fluid level was low.. I filled it but the steering never came back. Is there a way to purge air out of these systems?
Any help is greatly appreciated.
Pete
Ac 720,160,5050,5050,175,185,6080, 200
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2024 at 12:18pm
Did you put a new O ring in when you cleaned the screen?Sounds like its sucking air.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2024 at 9:04am
Remove the screen and run it for a few minutes. You have cavitation - 99% screen issues.. Assume you have separate reservoir - if it is full - loosen one power steering line at the cylinder- crank and turn steering wheel.
