Deutz 385 planter |
Russ-neia
Topic: Deutz 385 planterPosted: 11 Apr 2024 at 5:05am |
1. Used 300 series population monitor with blower control and power supply boxes 2. Two used seed hoppers 3. New clutch release cable 4. New speed sensor 5. New seed tube sensor 6. Seed meter housing with water pump bearing 7. New gauge wheel tire 8. Lot of three soybean air plates part 70581252 9. Lot of seven medium round and flat corn air plates 70585807 10. Lot of six large round and flat corn air plates 70586141 11. Lot of six small popcorn/sunflower air plates 70584901 12. Box of miscellaneous used blower parts Edited by Russ-neia - 11 Apr 2024 at 8:20pm |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5179 |
Posted: 11 Apr 2024 at 6:03am |
Just a suggestion, but you might have better luck posting in the Classified section of this forum.
plummerscarin
Posted: 11 Apr 2024 at 6:24am |
Would you happen to have seed wipers 71510366 (air cut off pad)
Russ-neia
Posted: 11 Apr 2024 at 8:21pm |
No, I do not. Have you tried getting them from Landoll?
plummerscarin
Posted: 11 Apr 2024 at 9:48pm |
That's the next step. Thanks
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1178 |
Posted: 12 Apr 2024 at 1:50pm |
Landoll has them. $45 a piece, its high but new pad will last for a lot of acres |
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
WdIndy
Joined: 13 hours 50 minutes ago Location: Indiana Points: 1 |
Posted: 13 hours 41 minutes ago at 2:32pm |
I see this post is pretty old but checking to see if you still have those planter parts available.
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 1003 |
Posted: 10 hours 28 minutes ago at 5:45pm |
WDindy, what all are you looking for?
Life is simpler when you plow around the stump.
