WTB 3-5/8 Allis dual hubs
TM(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TM(MN) Quote  Post ReplyReply Direct Link To This Post Topic: WTB 3-5/8 Allis dual hubs
    Posted: 10 Apr 2024 at 8:35am
Looking for a set of Allis 3-5/8 dual hubs. 10 bolt if possible but 9 bolt are fine. Call or text Trevor (320) 894-2126. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2024 at 7:05pm
Thought I seen somewhere a fella used JD hubs that worked in that size - but metric
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2024 at 8:07am
  I had one go bad, used a Junk Deere, it works.
CDN 400 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDN 400 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2024 at 9:30am
Would you happen to know what deere's had that size axle?
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2024 at 10:05am
part numbers for 3 5/8 hubs or 92 mm
71e20m 9 bolt
 91e20m 10 bolt
 fits A/C 210 220 7010 7020 7030 7050 8010 8030
 also fits John Deere 4420 4430 4440 4450 4455 4520 4620 4630 5010 5020 6030 7400 7410 7600 7610 7700 7710 7800 7810 8430 8630
book also says not all models use the same size check axle long axle may be bigger
I have one set of used 9 bolt , but someone has spoken for ,
can get new wedge style 10 bolts
Edited by steve fischer - 13 Apr 2024 at 10:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2024 at 11:48am
have set of 9 bolts 3 5/8  thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote TM(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2024 at 8:57pm
Found a set. Thank you for the call.
