ACC 40 fork lift
Grumpy1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grumpy1 Quote  Post ReplyReply Direct Link To This Post Topic: ACC 40 fork lift
    Posted: 09 Apr 2024 at 9:35am
I have an ACC 40 fork lift with propane. I need a radiator it was rammed by another lift and because there was just a makeshift grill the radiator was smashed beyond repair. does and one have any info about where to get a replacement. I just got the lift and know very little about. It did run and work well until accident. also need hoses for steering that got damaged in accident also. Any help please.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 1:07pm
If you can find a trustworthy radiator shop they may be able to line up a radiator core, by dimensions,  from their supplier and switch over the tanks from the old rad to the new core.
Any hoses you need should be straight forward to get at any outlet that deal with hydraulic hoses.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grumpy1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 1:57pm
Thank you but my bottom tank is destroyed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grumpy1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 9:06pm
I found an aftermarket radiator on ebay. my next question is does anyone know the size of the rear tires on the acc40 fork lift? mine are so beat up I can't identify them.
Edited by Grumpy1 - 26 Apr 2024 at 9:07pm
This page was generated in 0.186 seconds.
