tie rod adjustment
panelbeater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panelbeater Quote  Post ReplyReply Direct Link To This Post Topic: tie rod adjustment
    Posted: 29 Oct 2010 at 6:30pm
how do you adjust the tie rods on the d17?
http://s2.photobucket.com/albums/y45/panelbeater/
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 7:26pm
are you adjusting the front-end wheel tread or just moving the tie-rod?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 8:17pm
 call 1800-254-3116 will explain easier than the net  should not need a jack
Post Options Post Options   Thanks (0) Thanks(0)   Quote panelbeater Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 10:01pm
we are trying to adjust the toe, the clamps are loose and been spraying with pb blaster but cant make them wider.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 10:05pm
Might have to keep tapping on the tubing to break it loose....they get filled up with dirt, get wet, get rusty...etc.
A little heat might help too.
toe-in should be 1/16" to 1/8"
cbt1124 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbt1124 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2010 at 10:17pm
Take 2 hammers, 1 on each side if the outer tube where the threads are and hit the tube at the same time with both hammers for the full length of the threads. Toe in should be 1/16"-1/8 ". The center rib on the oem tire wears away quickly when driving on the road, keep it in the dirt and they will last forever.
