Honda 450 Foreman quad question |
Ben (MI)
Joined: 02 Jun 2010 Location: SW Lower MI Points: 770 |
Topic: Honda 450 Foreman quad questionPosted: 07 Apr 2024 at 11:19am |
Howdy,my new to me quad will leak gas out of the carburetor overflow tube when I park it for the day if I don't let it run out of gas after turning off the fuel shut off. Assume there is gunk in the float, carb repair is above my abilities. I'm running a heavy dose of Seafoam thru it.It starts and runs perfectly.There's not a line from the overflow tube to get the gas to the ground so if it does overflow it drips on the engine. I am going to put a line on it. My question is, the parts diagram shows a one way valve in line on the overflow tube. What does this valve do, keep water out if you are puddle jumping? Thanks for reading!
Part time farming with a 1980 7060 and 1984 F3 hydro.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89845 |
Posted: 07 Apr 2024 at 12:47pm |
valve is not necessary.. but yes, it prevents water, bugs, dust from going UP into the carb.... You dont have it now, so adding a foot of drain hose does not change anything.
Ben (MI)
Posted: 07 Apr 2024 at 12:48pm |
Thank you Steve
Vaterlemon
Posted: 3 hours 38 minutes ago at 8:06am |
Sounds like the float needle isn’t sealing. I’d pull the carb, clean the bowl, check the float height, and replace the needle and seat if they look worn or sticky.
