Paint Codes |
Post Reply ![]() |
J. Larsen ![]() Bronze Level ![]() ![]() Joined: 01 Dec 2023 Location: Lander, WY Points: 47 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Apr 2024 at 7:12pm |
Just have a couple of questions.
1. I got on the tech forum and found AC Paint codes. a. I'm guessing that persian orange #1 would be correct for a WD45. 2. Is there a specific silver color that is used on the wheels? I seen something called "Silver Mist". Is that a real color for AC? Thanks, JL |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4848 |
Persian Orange 1 (PO1) is correct for a WD45 (although I personally prefer PO2).
There are a lot of different paints that have been used on rims. Originally, they were galvanized. I have used Rust Oleum Cold galvanizing compound or Rust Oleum Argent Silver for rims.
Edited by WF owner - 06 Apr 2024 at 6:04am |
It looks to me, that the P02 is a little brighter orange. Where I'm not painting the whole tractor, just the wheel centers and the rims, I'm trying to match the rest of the tractor. It sounds like there is not a specific color for the rims. I appreciate the reply. It was fun getting all of the eccentric housings freed up and operating again. I hope that it wasn't just the rust inside the eccentrics that was keeping the wheels tight, and that they will continue to operate as designed.
Thanks, JL
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4744 |
I like the Rust-oleum spray, coats nice and even
![]() Edited by JoeM(GA) - 06 Apr 2024 at 11:11am |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3719 |
Joe, is that the Rustoleum galvanized? I used that on my 7040 rims.
yes it is
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8414 |
PO 2 is prettier but 1 is correct for a 45.
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 834 |
I use Tallmans aluminum paint, looks sharp and bright but not too bright like chrome.
I also paint all my bolts too with that…. |
1955 AC WD45 diesel with D262 repower, 1949 AC WD45
What are you using to mask the tires?
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11923 |
Hey Joe! That looks like a G rim......! LOL! I use Dupli-color's textured Silver. Looks a lot like Joe's wheel when dry. Also fills in some of those pesky rust pockets in the rim and makes the wheel look smoother. In NJ, the rust worm can get pretty harsh sometimes... Steve@B&B
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18910 |
The 45 color is kind of a drab orange, but that is correct. The correct color is WHAT YOU LIKE!! It's YOUR tractor.
![]() Here’s my 45 with Persian 1 orange, aluminum color rims, and rust oleum almond white. |
Steve, you know it's a G rim at my house! I have a stack of old file folders cut to the rim radius, just let the air out, pull the bead down a bit and slide them in, that galvanized spray even self heals if I scratch or bump one. Even if you touch them up, in about a month, you can't tell where it was ![]() ![]() |
rasman57 ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Illinois Points: 408 |
I discovered the deck of cards method for the tire/rim area and it worked well for me. Place the cards right in the seam next to each other and you are good to go. Don't use the family heirloom antique cards. I found cards are way cheaper than tape and even I can set em in and not miss a spot.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3732 |
persian orange 1 is a prettey color when it shines
Post Reply ![]() |
