170 175 tach
rick ky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Topic: 170 175 tach
    Posted: 04 Apr 2024 at 5:36pm
put together allis motor 226 with alternator from 236 diesel,  everything is coming together fine. red light works when key is turned on, goes out when oil pressure is increasing.  alternator is putting out 14 volts. fuel gauge is working properly. temperature gauge working, increasing when motor is warming up. tach is running around 1,000 on low idle, but it buries the needle at half throttle. parts book shows 2 different tachs, 1 for gas and 1 for diesel. we know the tach is original for the dash, it is a gasoline engine tach. what thoughts are out there on how possibly to fix the problem? we want the tractor to operate as close to new as my nephew will have his wife driving the square baler while he is loading the wagon.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 5:47pm
Got the wrong size pulley on alternator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 5:51pm
what size is a suggested diameter choice. thanks for input
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 7:46pm
If the rear of the alternator drives the tachometer, I thought there was different size gears in there for different applications
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2024 at 6:29pm
just fishing to see if anyone has come up with any ideas on changing gear in alternator or what size pulley should be on alternator
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2024 at 5:02pm
okay boys and girls we have put the largest pulley on alternator. what suggestions do you mechanics have now. is it in the tach drive on back of alternator. thanks to anyone able to shed any info on this problem. thanks again
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2024 at 5:16pm
Check the drive gears on the alternator and count the teeth for starters...big gear should be 46 if I remember correctly...some people have accidentally put 43 tooth gears in them and the tach reads faster.
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2024 at 8:32pm
thanks doug
