7030 water in tranny & Rearend
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Topic: 7030 water in tranny & Rearend
    Posted: 31 Mar 2024 at 9:20pm
Just got a dead open ROPS 7030 in. It has water in transmission and rear end. Shouldn't there be a rubber boot on the main shift lever? I see one for the Hi-Lo lever in parts book & Agco parts book doesn't show one for the main shifter.                                                 Also, what's best to flush with? I've Got access to 200 Gallon of old clean diesel. Tractor set for 3 years.   " It had no fuel to inside injection pump" per previous owner. Might have something to do with the 2" of black tar sludge in tank.  Going to rig up 12v pump on bucket to see how she runs.
Edited by fjdrill - 31 Mar 2024 at 9:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2024 at 9:30am
old diesel sounds like a good way to FLUSH out any water and Crap... Good drain and then proper reflll should be adequate... Hope you can get the CRUD out of the tank and pump is clean -  OK.
