Allis 170 perkins tach
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Topic: Allis 170 perkins tach
    Posted: 31 Mar 2024 at 12:29pm
My tach on the 170 doesn't quite work.  I replaced the cable because the tip was broke at the tach.  The new cable makes the tach work a bit but it sounds like some internal gears are grinding or slipping.  It only shows about 500 or 1000 rpms when up to operating speed, and the tach needle pointer is broke too.  I can't find a replacement.  The replacements are for 180, 190, etc.  Can mine be rebuilt?  Can I use the 180 tach that's for sale?  Thanks.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2024 at 2:31pm
There are parts to reuild the drive on the tach - the 180 will turn in the correct direction and uses the same Alt.
This page was generated in 0.257 seconds.
