PTO Generator/welder or Hobart? |
structures
Joined: 28 Feb 2011 Location: Beggs, OK Points: 336 |
Topic: PTO Generator/welder or Hobart?Posted: 31 Mar 2024 at 11:44am |
Looking for opinions. For a few years I've been wanting to buy a used diesel welder/generator or something like a Hobart 10k watt gen/welder. But the Hobart is now $5200 at Tractor Supply. Lately I've been thinking about maybe getting a Harbor Freight 15k PTO generator and maybe running a Lincoln tombstone welder off that. ~$2500. I'd be powering with my Allis 170 perkins diesel. What do you all do for remote welding and generator backup?
I can weld remotely but it's a 6500 watt generator and a small 220v mig. I'd rather stick, especially outside in the wind.
Robert
1964 D15 Series II |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35698 |
Posted: 31 Mar 2024 at 12:29pm |
Had a Gasoline powered Thermalarc Predator, great welder but Heavy and was always chasing Bad Fuel issues. Cousin has a Purchased Used Miller Diesel powered Trailblazer, runs it seldom enough pumps the fuel out until nearly empty before putting away as algaes out so bad over time. Six of one half dozen the other. BTW he paid close to $8500 for his used. Am at the point going to buy a Whole House LP generator, not incorporating Auto Start. Will have its own independent fuel tank.
Portable welder, likely buy a Bobcat used and convert to LP or drain gas every chance I get.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8404 |
Posted: 31 Mar 2024 at 12:37pm |
If given the chance, a pto generator with a welder plugged into that would be my option. It gives you the opportunity to ‘exercise’ the generator, that way it’s ready any time power outage happens. And you can use any tractor that’s handy, and not worry about stale/bad fuel.
KJCHRIS
Posted: 31 Mar 2024 at 4:11pm |
A tractor, PTO gen & an AC powered welder is all it takes to make a good portable welder setup.
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Posted: 31 Mar 2024 at 4:34pm |
The pto generator with Lincoln welder is all I have ever had for 40 years. I have run the Winpower 25kw generator with e everything from a D-17 to a 185 Allis. Actually welds better than on Power Company service.
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10413 |
Posted: 31 Mar 2024 at 4:38pm |
I made a trailer for my 40 kilowatt PTO Katolight generator. Made a provision to haul my AC welder. Works great when building fence in the pasture or a down piece of equipment.
DaveKamp
Posted: 03 Apr 2024 at 9:39pm |
I have four 'portable' welder-generators, I use NONE of them for backup power, because I've got a generator shed with generators specifically for that purpose. One portable is on a specially-made pallet that holds welding rods, gloves, shields, 4" grinder, a fire extinguisher, water sprayer, oxyacetylene torch rig, and floodlights... USUALLY it's sitting inside the shop door, and if I need to move it around the shop with a pallet jack, it easy. If I need it in the driveway, I pick and carry it with the Hyster H50H. If I need to go out into a field, or somewhere else of questionable terrain, I put forklift attachment on the D17 and drop a pin through the forks, so it cannot slide off... and away I go. If I need to go further, I can fork it onto a trailer, or a pickup truck. I have a 4cyl 10kw gasoline welder/generator mounted on the bed of my loader-crane truck. It doesn't power the crane's hydraulics (but I've considered it), but if I want to reach out and use the hoisting drum, the boom lighting, or some power tool, it works great for that. If I need to reach out and weld something, I use the crane boom to support the welding cables, rather than having to tie them off somewhere to keep from pulling me away from the work. My trailer-mounted unit is a Miller Bobcat, it will do CC and CV, I have a wire feeder and a gas bottle rack, along with stick leads. I don't have a scratch-start TIG torch on it (yet)... The smallest welder-generator is a V-twin Honda powered machine that is hard-pressed to melt a medium 7018 rod... so just keep it to a minimum. PTO generators are handy when you've got a farm emergency (like a poultry building that lost power to ventilators)... but for emergency power in an outage, I wouldn't do that, on account that a tractor running the PTO is incredibly fuel-inefficient... and you'll be carrying fuel cans for anything more than a few hours. My backup generators (there's 4) are all fed propane from a pair of 1000 gal tanks... I pick my generator SIZE based on anticipated load. Under very light loads, I'll be running a 2kw Onan. Add more (like cooking with microwave, or frequent sump pump cycling during rain) I'll start the 4kw Kohler 4cyl. I can bring up a 6.5kw four cylinder to get a little more 'headroom' (like microwave oven, dishwasher, air conditioner)... or if we really need it (i.e., baking, clothes dryer, running my machine tools, welding, etc) , I'll start the big six-cylinder Kato and run the whole danged farm... but running a really big engine for a very light electrical load is a significant waste of fuel...
