417 loader
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Topic: 417 loader
    Posted: 30 Mar 2024 at 6:00am
Anybody know what the capacity (in gallons) is of the hydraulic oil reservoir on a 417 loader? Mine has a leak and I was considering mounting an external reservoir, just not sure what capacity.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 8:01am
Two and a half gallons.
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 9:12am
Thank you
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 11:12am
fixing the leak will be easyer and look nicer
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2024 at 12:14pm
I wonder if the caswell epoxy liner would help fix your leak?  I've used it in a few gas tanks with great results.  It's expensive, but the oldest tank I've got is 6 or 7 years old without failure.  You'd have to take the loader tower off and get it setup to flip around making sure everything got coated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2024 at 12:29pm
just weld it
