Can’t get set screw out on new D17 bendix
bglancy28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bglancy28 Quote  Post ReplyReply Direct Link To This Post Topic: Can’t get set screw out on new D17 bendix
    Posted: 26 Mar 2024 at 4:48pm
Can’t figure out how to get this set screw out of my new starter bendix. It’s different than the old style as the spring is covered and doesn’t leave enough clearance for the set screw to come in or out. The link is the new part I got.
https://www.tractorpartsasap.com/starter-drive-prestolite-style-new-d2012-113968.html?gad_source=1&gclid=CjwKCAjw5ImwBhBtEiwAFHDZxwLwl3a5hrBrmqWJHErYv-Ze60KNPlfX01vTx7LHyr825xwNVrSnQRoCLXYQAvD_BwE
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 5:39pm
compress spring inside far enough to use a bondus ball hex wrench to back it out .
Post Options Post Options   Thanks (0) Thanks(0)   Quote bglancy28 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 5:40pm
I can’t figure out how to post a picture on here but it’s not an Allen set screw it’s a flathead. Also that’s the problem I can’t get it to compress far enough to clear the outside of the set screw.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 8:35am
Well, been there done that! Had to take a die-grinder and cut a notch to get to the screw. What was worse, the drive was about an inch too long. Took it back and they did refund my money at least.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 10:14am
I got this from FB. I believe it was your post. Hope it helps.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 3:12pm
That kind of drive was on our old cat lift trucks. I would put it in a vise and compress it enough to let it go past that collar then put it on the shaft and then tighten it up then remove from vise
Edited by john2189 - 27 Mar 2024 at 3:13pm
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2024 at 9:27pm
if its about an 1 inch to long did you get it racheted out ? it  will neeed to be spun to get it where it belongs then it wont be hard to do
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 7:46am
I took mine back to all states ag parts, that's where I got it. Frustrating experience!
