Lock n lube grease coupler
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Lock n lube grease coupler
    Posted: 26 Mar 2024 at 8:34am
Finally got one
Works good
Have 8 bearings I lube before using my disc harrow
Should've gotten one sooner. Thanks
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 8:54am
That company WILL stand behind it's products too. Cost a bit more than the chinese copies but well worth the cost differential if keeping for a long while.
That's All Folks!
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 9:03am
I keep looking at those and thinking about trying one. I think they'd work great, but I keep thinking the places I really want to use them (like u-joints) they won't fit into anyway...
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 9:10am
  They do work great, wont start leaking only after a couple try's. I keep two guns, one for nearly everything and the one with the junk ends for the tight spots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 9:11am
They have a plethora of adapters available for most any application.
I got no skin in this game but strongly support any company that goes the distance with their products. This one has with me and I use their couplers daily numerous times.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 9:56am
battery operated grease gun helps.... Keeps one hand free !
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 10:50am
I have one, haven't tried it yet.  It sits in grease gun drawer. Need to put it on.  I have an air powered grease gun.  I just put a whole (full size) tube of grease in my disc - I guess it'd been too long...  A battery powered one is tempting.
Edited by GSTROM99 - 26 Mar 2024 at 10:53am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 10:51am
When replacing grease gun ends, keep in mind there are those cheaper ends that have 3 joints that grip the alamite - the premium ends have 4 quads that grip.  The good lock on ends are great - with the exception of high pressure areas that are hard to get to - then it is hard for this old man to pull the 'trigger' to get the unit uncoupled.  Also if anyone has a brand of grease gun that does not eat grease let me know. I can put a tube of grease in - use it one time , and the next time I go to use it, it is empty again !  Surely they are not all like that :-) ... ??
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 11:11am
Tim πŸ˜†πŸ‘ŒπŸ‘
Blue Skies and Tail Winds
                          Dana
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 11:38am
we pump grease guns full from a 5gallon bucket.   and have about every grease gun end knowen to man for differant spots.         one of my customers gave me a lock and load brand coupling and it has been used enought to empty one five gallon bucket full of grease gun refills still works excelant and it doesnt leak.         it came with replacement parts also that i havent used yet ,   i have try other brands of lock on ones and dont like them mostly because i cant get them off .    i would buy anthor lock and load coupling  agian
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 12:05pm
Milwaukee M18 battery powered grease gun is expensive, but worth every penny if you use a grease gun often. They have awesome warranty and service too. Mine gets used heavily at work, and moderately at home… and lasted just over 5 yrs before i had to send it in for refurbishing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 4:42pm
I bought a couple locknlubes when they first came out. Nothing but ravesThumbs Up from me.  I could lock the coupler to the upper hinge bearing on the round baler, and hoist myself up by holding onto the hose, and it would still work even after such abuse...
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 5:59pm
I have a Dewalt greaser that has worked for a couple of years now.The lock n lube ends were a bit short for the combine header grease points but they came out with a longer model.Perfect now.It saves dozens of hand pumps on the hay rake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 6:44pm
Used mine again today. Still works good. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 7:05pm
My son Ian gave me one 3 years ago in a Christmas present bundle. I kept it in my shop amongst the other cheepos fittings until last summer I tried it. Why did I wait so long???😒
                          Dana
1963D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2024 at 7:27pm
I have one on my Milwaukee grease gun. They work great.
