200 wheel wedges
Fritz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fritz Quote  Post ReplyReply Direct Link To This Post Topic: 200 wheel wedges
    Posted: 24 Mar 2024 at 5:11pm
What’s the trick to breaking them loose? So far have the puller holes cleaned and lubricated, and the bolts pushing on flat pieces of steel so as not to mar the holes in the wheel… but nothing is moving yet. Someone before me had been pounding on the wedge so I took a few half-hearted licks with a 20 pound sledge but nothing still. Thanks Fritz
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2024 at 5:20pm
Put alot of tension on the bolts- hit the end of the axle with that sledge,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2024 at 6:08pm
Flat pieces of steel ??? You must not be using the official A-C axle wedge removal bolts because they don't require any such thing and you'll probably be unsuccessful until you have the correct tooling.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2024 at 7:17pm
I've done what Doug suggested and had success every time. OneNinety's -D21.
Now the two piece takes the special pusher bolts for sure
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2024 at 10:06pm
You were lucky. If the wedges are truly extremely TIGHT, that method won't work, so quit encouraging him. Beating on the wedge with a sledge hammer is counterproductive. Beat on the end of the axle shaft while using the CORRECT pusher bolts under pressure.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 5:47am
Be careful pushing against flat steel.  I tried it back in my younger days once and 2 things happened... First it mushroomed the end of the bolt so I had to cut it off to get the bolt back out.  Second it pushed the steel into the hole some, but luckily it didn't mess up the threads, but definitely could have if I had gone to town on it.  Get a set or make a set of pusher bolts if this is the first time getting it off.  I did pop the wheel off after tightening it down that same day with a piece of plate steel and a bolt, but it was coated in anti-seize and had just been tightened that same day (had already returned the pusher bolts I borrowed).
-Hurst
1979 Allis Chalmers 7000
5800 Hours
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 8:05am
Hey  Fritz :   I have a wheel wedge puller that does  not use pusher bolts.  If you do not have  Allis Chalmers pusher bolts and the wedges are super tight, i may be able to help you out. Be carful beating on axle or other wheel parts. Dale Hardtke  Watertown Wi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fritz Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2024 at 9:31am
I do not have the official bolts. I took the steel back out and sure enough, they were about to be punched all the way through.
   I did wonder why the bolts never came to a hard stop… it did doink up the threads a little but I was able to reach through with a 5/8-11 tap and get back to square one.
This page was generated in 0.289 seconds.
