D 15 oil pressure
ACinSC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 oil pressure
    Posted: 22 Mar 2024 at 6:15am
When it's hot (190 degrees) my gauge reads about 5 psi at low idle and about 15 psi at full throttle. Guess this is normal for a well worn gas engine? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 8:06am
A D15 should have the FULL FLOW PH8 type filter ??   15 psi is a little low, but like you said, its OLD and thats what you get. As long as you have FLOW it should be OK....What viscosity is the oil ?  New filter ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 8:17am
Thanks Steve, it's time for a oil change. Can't remember if I used 10W30 or 15W40 rotella. I have it written in my maintenance log out in the shop. Yeah I'm thinking it's full flow.
Edited by ACinSC - 22 Mar 2024 at 8:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 10:21pm
We run AGCO filters on our tractors, our D15 series II runs 3/4 on the normal range of the factory gauge but we rebuilt the engine last year. Not sure what psi range that is though. Assuming maybe a 30 psi gauge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2024 at 6:45am
Thanks Robbie
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2024 at 8:44am
When I first acquired my D-15 Series I, it also ran a little low on oil pressure.  However, When I changed the oil with high quality 10w30 and installed the AGCO oil filter, all was back to NORMAL.  With pointer on the R.  Good Luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2024 at 10:51am
Thanks EPALLIS , just checked and I'm running 15W40 Rotella and a NAPA Gold filter .
