New to me ac 7060 |
Post Reply ![]() |
Doctohay ![]() Bronze Level ![]() ![]() Joined: 21 Mar 2024 Location: Nw ks Points: 10 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Mar 2024 at 9:46pm |
Hi yall. Quick intro. Retired USN currently delivering usps. Just bought a ac 7060 and want to learn as much as possible. Gonna put it into service for my small 12 acre hay operation (just starting). Have a small square baler and rake. Just trying to get something back from my land and possibly some custom stuff. Also have a 14 ft disk drill and other implements.
Edit to add without getting into a rabbit hole of oil (lol) what is the general consensus of fluids to use. Edited by Doctohay - 22 Mar 2024 at 5:14pm |
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3237 |
Welcome to the AC forum. Thank you for serving our country.
7060 info please? 1. Serial number is stamped in upper left pto housing. 2. Maroon or black belly(painted?) 3. PD or PS transmission? PD is power-director 5x2x2(gear shift on floor or T-handle in console 20 speed). PS is Power shift 6x2 console shift(12speed) |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8602 |
X2 on thanks for serving our country, and glad to have you joining the forum. I have had a 7060 black belly power shift for around 10 years now, and it is probably the tractor that gets used the most of any of them. I guess that one quick note I'll make, because a lot of first time allis owners don't realize it, is that the PTO is changeable between 540 and 1000 RPM by removing the ring of bolts around the flange on the PTO shaft, pull the shaft out and flip it around and put back in. Reinstall the bolts in the ring of bolt holes opposite of what you took them out of. 1000, bolts go into inner circle, 540, outer. Holes are not symmetrical, so only one way the bolts will all go in. NEVER have some bolts in the inner circle and some in the outer. I seen one person do that, it'll probably cost you more to repair than the tractor cost you. All in all, you should love the tractor. Sounds like it may be bigger then what you need, but you can do big and small jobs with a big tractor, but can only do small jobs with a small tractor. Good luck with it. Do you have an operator's manual?
Darrel |
I’ll try to answer the best I can. I need to get the serial number later. It’s not a black belly ac. PD shift. (5 on the floor) a/c and heat, (to be determined if it works later) radio that doesn’t work. Newer tires all around.
Thanks for the welcome. I knew about the pto but thanks for the heads up. No I don’t have an operating manual. I’ve used this machine a few years ago to drag a paddle scraper to fill in a silage pit. Still I’m an amateur. I think the first thing I need is a driver door upper window rubber gasket. New filters all around and an oil change. Oh yeah I also need a cap that goes on a full hole that is located in the back and above the pto. So if anyone has a solid place to buy parts and such please let me know. Thanks again.
Tractor’s Rear-end Hydraulic Fluid fill hole is what your describing. Wanna keep on hand some AGCO power fluid 821 or a comparable Premium Trans-Hydraulic Universal Oil. Your local farm & fleet usually carry 5 gallon buckets of it that list 821 on its back label?
Keep the 821 level between tractor’s two glass sight knobs located on left side of rear-end housing. Maybe try AGCO for that fill hole plug/cap? Use agcopartsbook.com to lookup any part online. Think you pick your local dealership, then type in 7060 for model. Parts will display & will be listed either available/in-stock/price or NA(not available). If NA, then try Colfax for any salvage parts. They’ll ship it to you. Here’s there website. https://www.colfaxtractorparts.com/ |
Thank you
Ok here’s what I found. It was on the upstairs upper right of the pto though. 265491-03-03-wa. Then right below that it is m18a
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19757 |
Above the PTO shield to the left STAMPED into the casting 7060-XXXX
I’ll need to clean up the area and check again
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 6744 |
Do not fully depress clutch when coming to a stop, you will engage transmission brake and shorten its life.
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
Thanks, I really appreciate all the tips.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2869 |
The decals in the cab explain this well the multi position clutch is super handy. I miss it in other color tractors. We have a 7060 and don’t use much anymore but it was a key part of us getting started. I guess I’m picturing the stickers in my 8030/50’s still the same concept.
Edited by victoryallis - 24 Mar 2024 at 9:26am |
Sorry to get back to you so late. The serial number is a 1492 if I remember correctly. Definitely a 14xx series. So that puts it at an early date doesn’t it?
Maroon/brown chassis color with gearshift on the floor. S/N 3001 and up were the black belly version with Tee-twist shifter on the console.
This one is maroon belly gear shifter on the floor. It 1429 to be specific. I was just out there and looked at it. Gonna go get a disk ready to prepare the hayfield for planting soon.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8089 |
That fill plug is vented so don't cork it solid. I forgot to put mine back in once and lost it. Had no luck with salvage yards ended up buying new. $100 plus 5-6 yrs ago. Zip tie it to nearby cable with a small hardware store chain.
Post Reply ![]() |
