Allis Chalmers 160 perkins 3 cylinder crankshaft |
Post Reply |
Swanb1
Bronze Level Joined: 21 Mar 2024 Location: Illinois Points: 4 |
Posted: 21 Mar 2024 at 6:49pm |
I am rebuilding a 3 cylinder perkins ad3.152 diesel on a Allis Chalmers 160. The crankshaft has removable weights. When I transfer these weights to the new crankshaft does the new crankshaft need balanced?
Edited by Swanb1 - 21 Mar 2024 at 6:52pm |
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 2050 |
I've not worked on one of these engines in the past but have seen them. I would probably have the rotating assembly balanced with both the flywheel, and harmonic balancer if equip bolted on. Along with balancing, weight matching of connecting rods and pistons to the lightest one will make for a very smooth running engine when assembled.
A career built on repairing and improving engineering design deficiencies, shortcomings, and failures over 50 years now.
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3291 |
WE never rebalanced them, but common sense tells one that any reciprocationg mass benefits from a preciaion balance - the question you have to ask yourself is do you feel lucky ? Just kidding - you have to weigh (pun intended) the $ vs what you intended use is. Do you want to brag about the money spent for a smooth purr or just put it to work . Where did you find a splined crank ?
Swanb1
I ordered it from yesterday's tractors.
https://www.yesterdaystractors.com/70280077_Crankshaft_29765.htm Good or bad I don't know figured they are all from China just different boxes. I talked to a few guy around here that has worked on tractors 40 years. Some said they have swapped the weights over and no balance, some said they have balanced. A couple gentlemen on here said balance. I have not clue that to do. In the end I just don't want it to fly apart. |
steve(ill)
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 81064 |
You would HOPE that all cranks are turned to SPEC and measurements are all within a few thousandths from one to another... That should tell you that the BALANCE is very similar between cranks..... like tbran said, its a GOOD IDEA... but you should be REAL CLOSE without balance... How many times have people rebuilt a motor and replaced a BAD ROD or installed NEW PISTONS and never done a balance ?
Swanb1
That is my thoughts exactly. Because the old crank didn't have any balancing done. But the quality of the parts now is not the same either.
Post Reply | |
