Snap couple equipment tongue length
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: Snap couple equipment tongue length
    Posted: 19 Mar 2024 at 10:30pm
On Snap coupler equipment ...are all the tongues with the snap coupler loop on them the same length? Or does some fit the D series and not WD series or vice versa?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2024 at 4:42am
I think there are 3 lengths, IIRR. Shortest to longest, B/C/CA  then WD/WD45, then D Series.  If I'm wrong, someone will chime in...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2024 at 6:57am
The WD/WD45 and Large D tractors use the same length pull bars, However the D series implements need longer lift links to avoid contact with the bottom of the Trans/Lift housing.
 The B,CA, D10/12 implement are completely interchangeable between all 4 tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2024 at 7:49pm
Thank you!!
