220 engine swap
Agcosucks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agcosucks Quote  Post ReplyReply Direct Link To This Post Topic: 220 engine swap
    Posted: 18 Mar 2024 at 9:14pm
Opinions on swapping a 7080 motor into a 220?
Dkranawetter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkranawetter Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 9:34pm
Good luck champ, back in my day we didn’t take good tractors and tear them up for pulling reasons.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 9:55pm
Just google 220 or 210 Allis and look at the pictures. A bunch. Just look at which way the oil filters point and the intercooler. 3500 vs 670 block. ...and this is the pulling forum...only issue is lower radiator hose...fan...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agcosucks Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 9:59pm
The 7080 motor is going into my 220 puller. I know the blocks are cast different but it should bolt up the same I assume?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 10:07pm
Yes, as stated IF you are talking complete swap, the location of lower radiator hose and the 220 has a hyd drive pump set up intact.  If you have intentions of a front plate swap for a different pump you have a lot of fabrication anyway. The 7080 has the preferred counterbalanced crank and the ability to run an inline pump w/o a harrison style drive as the pump hits the block on the 220 w/o relocation.
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 7:02pm
It's a LOT of work,I put an MK II 3700 irragation
motor in my 210,yes it can be done,yes the block will bolt
up to the bell housing,however If I can remember some
of things I had to doIt's like one step forward and 2 steps back.
I'm not familiar with the 7080 engine,but if you keep the
hydraulic pump for the 220 you will more than likely run
into issues there because if I remember right the front plate
on the 7080 wont work for the 220 hydraulic pump,and if
you try to use the 220 front plate you will have to work on
it because the 3500 and 3700 oil pumps are made different and the 220
plate hits the pump..You can get around water pump and radiator not being on same side but you will have to do some crazy plumbing there to get hooked up and the upper radiator hose will be an issuse too.
And probably some issues with the turbo and air intake pipe..
These are just a few of things you will have to figure out that I can
remember off the top my head,oh,you may have to cut the hood some
on the intake side as it hits the hood there,good luck and it will take a lot of time,it's not as simple as you might think but can be done...
Sorry to be so long...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 5:40pm
Have you started your project yet,curious to see how things are going.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2025 at 7:12pm
have engines and blocks for 220
