h3 fuel tank |
orange80
Topic: h3 fuel tankPosted: 18 Mar 2024 at 3:35pm |
hi everyone im new here just picked up a h3 crawler that needs a fuel tank i was told h3 was based off d14 and d15 tractor i was curious if anyone could confirm if a tank off a d14 or 15 would fit my h3 thanks, eric
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1009 |
Posted: 18 Mar 2024 at 3:57pm |
The D15 tank would be the right fit. A D14 tank may work but is narrower than the D15 tank and would not match up the the hood panels.
AMB(wcIL)
Joined: 03 Oct 2009 Location: Chapin Il Points: 328 |
Posted: 18 Mar 2024 at 7:09pm |
A dozer tank has a tube at the bottom sucking from the center of the tank to the sediment bowel in the corner. Yes a D15 tank will fit and work, but you might run out of fuel on a steep hill side. We have a H3 and I can see the tube in the bottom of Our tank. Andy
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5274 |
Posted: 18 Mar 2024 at 7:27pm |
I have a good D15 tank available here in Maryland, very near Gettysburg, PA. PM me for details.
Codger
Posted: 18 Mar 2024 at 8:06pm |
[QUOTE=AMB(wcIL)]A dozer tank has a tube at the bottom sucking from the center of the tank to the sediment bowel in the corner. Yes a D15 tank will fit and work, but you might run out of fuel on a steep hill side. We have a H3 and I can see the tube in the bottom of Our tank. Andy[/QUOTE Had that problem on an older JI Case dozer using a farm tractor tank. I silver soldered the tube into the center of the replacement tank and it discharged to a remote mounted sediment bowl and filter. Not original but worked well.
That's All Folks!
