Forum Home Forum Home > Allis Chalmers > Farm Equipment -Knowledge Base
To4b80 Turbo questions
studer automotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Topic: To4b80 Turbo questions
    Posted: 18 Mar 2024 at 3:07pm
I’m looking for a PN for a replacement to4b80. I came up with a 313099 PN off a borg Warner turbo , which replaced a tob490, which I believe is a replacement turbo for a d21 or 210/220. Im installing it on a d19 D so that’s entirely to big. Anybody have any input on this?
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4
86 mustang5.0 owned since 8/93
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 9:57pm
It's been 45 years, but I'm pretty sure the D-21 and D-19 used the SAME turbo, which was a Thompson brand which later became a Rajay. I always thought that was interesting, but that D-262 couldn't stand much boost and the bigger size was just what it took to keep boost relatively low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 10:59pm
Interesting, I have a ray-junk turbo on my 19 now i’m looking to replace it with a b-w or garret. I found brand new borg Warner turbos for $450-$500. Thanks for the info dr.
99 f-250 7.3 4x4
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 9:09am
TO4B80's came with 2 different exhaust housings. The D19,190,200 all used the .69 A/R housing. The 7020 and some combines and industrial (gen sets) used the .58 A/R housing for about 2#'s more boost or the same boost at lower RPM.   The TO4 B90's were used on the 426 engines up to the 8000 series. They used 2 housings as well. Some combines, industrials, used the smaller .8 A/R  but most had the .96 A/R housing.  The smaller A/R housings forced more air to the turbine and spun it faster for more boost. The larger A/R's allowed some gases to escape around the turbine. The A/R # is usually stamped in the exhaust housing inside or on the radius. (some of the later China, perhaps, castings have no stampings)
Edited by tbran - 01 Feb 2025 at 9:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 12:20pm
Good info!!! Thanks
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 9:32am
The Turbo I finally found to fit my old 7G was on ALL STATES AG PARTS, contacted Air Research(Garrett) and confirmed would function as a replacement, most of these were Altitude Compensators NOT High boost Super Charging turbos, just meant to clean up Combustion.
This what looking for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2025 at 8:20am
Another great example of the after-market world claiming that one turbo belongs on all those different machines. To start with, a D-17 never had a turbo. This turbo would be a replacement for an Air-Research brand, not an old Thompson or Rajay (D-21 for example) or some others that had Rajay OR Air Reasearch offered. You can't replace one brand turbo with another brand turbo and not make many plumbing changes. I'd say it is probably a 301 sized turbo, not a 426.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 6:45am
Sorry Doc, but swapped many a brand of Turbo on Cummins Detroit and other engines as the OEM Manufacturers disappeared, So long as Volute Housings were produced to the old Specs any physical differences in appearance made no difference.  Biggest issues in swaps were generally Plumbing for Oil Feed and Return, or re-clocking housings.  Boost off the replacements was only limited as to discharge volumes based of Fuel consumption on the engines, generally they ran cleaner than the last units coming off had been.
Newer Turbochargers have developed to Roller Bearings rather than the old style Floating Bushings designs, accept oil SLOWER, requires a decent pressure available as well volume, and do not have as much issue with roll down damage with no oil as the older units once saw upon engine shut downs.
Edited by DMiller - 26 Feb 2025 at 6:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 7:14am
For example, if you try and swap and Air Research turbo for a Rajay brand turbo on a model 7000 tractor....everything is different. The cross-over pipe, oil feed line, oil drain line and in the case of a 190XT or 200, even the J-tube/air inlet is a different length. The only thing the same is the exhaust manifold and intake manifold. A Rajay is physically 1 to 1 1/2" shorter front to back, so everything is positioned differently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 8:08am
Position differences are manageable if cannot attain a antique that has not been built for thirty years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2025 at 3:54pm
The last Allis built was 40 years ago - the D19 60 years -- hard to believe...
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 11:55am
Back on this topic, but looking for a P/N for the smaller A/R exhaust housing….. TIA
99 f-250 7.3 4x4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 1:06pm
Find yourself a turbo 301 engine that is a gen-set engine. If it is new enough to have the TO-4 series Air-Research, it should be the tighter .58 exhaust housing, because it only runs 1800 RPM to make electricity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2025 at 6:34am
I ran into the same problem when I was looking for a replacement a while back, the 313099 is definitely too much turbo for a D19, it’ll spool way too late and just make it a pain to drive. I ended up going with a smaller T04B trim that was originally spec’d closer to what the D19 can handle, and it’s been a lot more responsive without killing power. If you can find something that was used on a D17/D19 setup, you’ll be much happier with it than trying to make the bigger one work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2025 at 7:05am
I found a brand new .58 oem housing
99 f-250 7.3 4x4
