D17 series 4 gas starter drive replacement
bglancy28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bglancy28 Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 4 gas starter drive replacement
    Posted: 16 Mar 2024 at 1:04pm
Tore apart my starter and found the spring was broken on the starter drive. Ordered a new starter drive replacement to my local parts store but not for sure if they got the right part. Anybody know what part I actually need? Trying to upload a picture but it won’t let me. I also lost the set screw that ties the starter drive to the shaft. It’s a set screw with a pinned end. Anybody know where I could buy a new one?
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 2:05pm
IF it doesn't look exactly like the broken drive, it probably won't work.
The Delco Remy starters and Prestolite starters on D17 gas share the same 9 tooth drive.
 Any shop that repairs starters should have the pinned set screw, or check with local AGCO Dlr.
 My local NAPA store used to have several assortments with misc parts for Distributors, Starters, Generators, early Alternators. I've no idea if it was just them or if they're common.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 3:01pm
Most of the new drives use a shielded clutch mechanism instead of the old spring design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bglancy28 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 6:30pm
Thank you. I ordered the part through Napa. Going to call remy delco in Pendleton, IN as they’re the closest to me and more than likely the same place this starter came from in the first place. For sure original. Only reason it broke was the top bolt backed its way out enough to make the starter loose and I’m guessing the flywheel caught it and broke the spring at some point. Guessing i finally got to the point that the starter wouldn’t hit the flywheel as I’ve never checked the bolts in the 15 years I’ve been running the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bglancy28 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 6:32pm
That’s pretty much all I can find. Hoping whatever part I’m getting from Napa will work. Thanks for the info because I was wondering if they changed it moving away from the spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 7:31pm
I have a few NOS Delco drive springs for both CW & CCW rotation starter drives.  I'd need a picture of what you have to know which you need. I probably have the drive screw you need also.
Edited by PaulB - 16 Mar 2024 at 7:31pm
